Shark Flex DuoClean Drive Belt Replacement
  1. Shark Flex DuoClean Drive Belt Replacement, Garage Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Drive Belt Replacement, Garage Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Drive Belt Replacement, Side Component: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Drive Belt Replacement, Side Component: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Drive Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Drive Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
    I know it is absolutely essential to have a security bit on here to change the belt as you wouldn't want anyone accidently changing it.
    Deb Winters - crwdns2934203:0crwdne2934203:0
  4. Shark Flex DuoClean Drive Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Drive Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Drive Belt Replacement, Drive Belt: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Drive Belt Replacement, Drive Belt: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove old the belt from the two gears by prying it off using the metal spudger.
    • The new belt will be very tight and difficult to put back on. In order to reinstall, start with the belt on one gear, then slowly rotate the other gear, pushing on the belt and allowing it to catch the teeth.
  7. Shark Flex DuoClean Drive Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat on the other side of the vacuum.
    what size of belt on this side?
    Juan Palafox - crwdns2934203:0crwdne2934203:0
crwdns2935229:010crwdne2935229:0
Christian Fuller
crwdns2935283:010/08/18crwdne2935283:0
423 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G5, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G5, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G5
crwdns2947412:010crwdne2947412:0
Thanks… Would have taken me forever to figure out how to get to the belts…!!!
Mike Babb - crwdns2934203:0crwdne2934203:0
Wonderful directions and a great help, thanks. However one important factor was left out, the part number for the belts.
Dave Orr - crwdns2934203:0crwdne2934203:0
Where to get the carpet brush belt? What would the belt size be?
Silver Dominator - crwdns2934203:0crwdne2934203:0
Add me to the rest. I also want a belt. Does anybody ever respond to these questions?
I’m hopeful we can find a source
ShellyB
shellyb -
the belt, roller brush, entire floor unit, etc are on amazon
john smith -
Just been told by shark that you cant buy the belt in the UK and you have to buy the whole new head at £60!
What a rip off! Wont be buying a Shark again!
graemefromhaworth - crwdns2934203:0crwdne2934203:0
When you say buy a new head does that mean the whole floor unit
Thomas - crwdns2934203:0crwdne2934203:0
They made me buy a whole new motorized head for $99 last year. Just the duo roller doesn’t spin making it harder to push around. I still have the broken head so I think I want to take it apart and see if it’s just the belt. The new head cracked by the rear right wheel so maybe I can Frankenstein a good working one.
Keith Sauer - crwdns2934203:0crwdne2934203:0
I have a shark rocket duo clean. I'm confused. Will have to wait if Shark will help?when i ring them. Pulling the foot apart seen to be allot of work if you don't just to be to the belt not knowing what you are doing or buy a new vacuum foot . Wish life was made easier
lowe.m - crwdns2934203:0crwdne2934203:0
the belts for this are $6 on amazon part #x003p9e50v, you need a torx #10 to get into it and the sides are not easy to get off, seems a little harder then it should be to replace belts
john smith - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 113
crwdns2942667:0crwdne2942667:0 56,516
