Shark Clean Sense HP102PET Shell Replacement
  1. Shark Clean Sense HP102PET Shell Replacement, Outer White Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement, Outer White Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement, Outer White Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off and unplug the air purifier before beginning.
    • Unscrew the one 1.2 cm screw holding the grate at the top with a TR10 Torx screwdriver.
    • Use a prying tool to carefully pry along the outer edges to disengage the inner retaining clips.
    • These retaining clips can be difficult to disengage, but releasing two clips on the same side should allow you to easily remove the grate.
    • Remove the grate.
  2. Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.2 cm screws with a TR10 Torx screwdriver.
    • Almost all screws are the same length (around 1 cm). The main difference is the bit that's used to remove them.
  3. Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four 1 cm screws.
    • This will make the fan holder slightly loose, but this will not be a problem until you open the case completely.
  4. Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over and unscrew the bottom by turning it clockwise.
    • Remove the filter.
  5. Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 1 cm a Phillips screwdriver.
    • Unscrew the four 1.2 cm screws with a TR10 Torx screwdriver.
    • The ring will not be hard to remove, but be careful on reassembly. Make sure that the power connector is properly seated when putting the ring back on.
    I just took my model apart (purchased in 2023) and for this step mine only had T10 1.2cm screws on the shell seams (I have 5 total — 4 for the seams and 1 that holds down the top grate). The rest of mine are Phillips 1cm screws. Just in case anyone with my model follows these steps to put everything back together!
    Maddie D - crwdns2934203:0crwdne2934203:0
  6. Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 1 cm screws that secure the fan housing.
  7. Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that you are pulling up on the side that allows, as pictured in the red box.
    • Gently slide the cases up and down, or hold one and gently pull up on the opposite side (Down on the left, up on the right for this picture).
    • The whole case will start to separate and the black disc will come loose. This is normal.
  8. Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Clean Sense HP102PET Shell Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently open the case outwards as there are fragile electronics inside.
    • Remove the fan housing.
KyreseAguilar
crwdns2935283:008/28/24crwdne2935283:0
727 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 7-14, Kilpatrick Fall 2024 crwdns2935289:0University of North Texas, Team 7-14, Kilpatrick Fall 2024crwdne2935289:0
UNT-KILPATRICK-F24S7G14
Thank you for this! My air purifier was making noise and I couldn’t find any guides to take it apart. This helped me clean it out and get rid of the noise! :-)
crwdns2942667:0crwdne2942667:0 188
