Pro Data is designed for repair: with two standard screws, its service panel can be removed, permitting access to the chassis interior for component replacement.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.16
Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
