Sennheiser HD 4.50 Volume Control Button Replacement
  1. Sennheiser HD 4.50 Volume Control Button Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sennheiser HD 4.50 Volume Control Button Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sennheiser HD 4.50 Volume Control Button Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the side designation on the headband-earpiece junction.
    • The motherboard is located on the right side.
    • Remove the right side ear pad.
    • Refer to the Ear Pad Removal guide for more guidance.
  2. Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry off the cover.
  3. Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the four 6 mm screws holding the motherboard in place.
  4. Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the hot glue that covers the wires
    • Using the tweezers, grasp and slowly pull away the wires from the motherboard until they disconnect.
  5. Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tools to lift up on the motherboard.
    • While lifting up with the tool, grab and pull the motherboard with your free hand away from the button functions until it disconnects.
    • There may be some resistance in this step.
  6. Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the three wires that are on the underside of the motherboard now that it is free.
    • Remove the motherboard.
  7. Sennheiser HD 4.50 Volume Control Button Replacement, Volume Control Button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to push the outer portion of the volume control button through the opening.
  8. Sennheiser HD 4.50 Volume Control Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers, grasp the portion of the volume control button that is connected to the inside of the ear cup. Pull away until the button disconnects.
Grace Singley
crwdns2935283:002/19/21crwdne2935283:0
628 crwdns2915208:0crwdne2915208:0
University of Alabama, Team S2-G1, Bedsole Spring 2021 crwdns2935289:0University of Alabama, Team S2-G1, Bedsole Spring 2021crwdne2935289:0
UA-BEDSOLE-S21S2G1
crwdns2935297:017crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Thank you! This helped me open my pair of headphones, and I was able to fix an intermittent connection to the headphone jack (by reheating the pads).
Marc Scattolin - crwdns2934203:0crwdne2934203:0
I should add that the diffuser for the LED should be pulled off by user before trying to lift up the board, as it will not come off out of it's hole by itself and it does block the board from being lifted.
NekoiNemo - crwdns2934203:0crwdne2934203:0
So urm, where do you get the replacement volume control board for replacement? Not just the button but the control board? It is not listed here?
Brandon Dyzel - crwdns2934203:0crwdne2934203:0
Or do you just desolder the three wires and then leave it as is? I'm confused with this guide.
Brandon Dyzel -
crwdns2936753:030crwdne2936753:0 108
crwdns2942667:0crwdne2942667:0 4,439
