This guide will demonstrate how to replace a faulty battery for the Sennheiser HD 4.50 BTNC. If the device does not respond when buttons are pressed, the battery might be the issue. Before beginning this repair, the headphones should be disconnected from any external power source, such as a charger.
Locate the side designation on the headband-earpiece junction.
The battery is on the left side.
The motherboard is on the right side.
Remove the ear pad from the left ear cup.
Use a Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
Use an opening tool to pry open the cover.
Remove the cover.
Use a spudger to pry the battery from the plastic case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, pull the white battery connector upwards out of its socket.
Remove the battery.
crwdns2935229:010crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Hello ! Thanks for the tuto. Do you know where to buy the battery ?
You can search with the part number(Shown in the photo) : AHB622540N1/AHB622540N01.
Where i can find it
Does anyone know if I can use the he 450 bt replacement battery in a 350 bt headphone? The difference in the spec is that the 450’s battery has a longer battery life (2.2 wh vs. 1.3 wh)
This was pretty straightforward, but in opening the cap one of the tiny soldered wires pulled off the pad. It's so tiny that I don't have much hope of soldering it back. Any other way to reattach it? I put it back together anyways and now the right cup works fine, but the left is dead. I recommend a warning here about the little wires, if nothing else.
How do u detach battery from the wire? There is a very thin board and two ribbons attached to the battery. Not sure how to separate with tearing ribbons.
My HD4.50's are 10 years old, I've only had to replace the ear muffs and just today the battery. These are the best headphones I have owned in ages and keeping them running for even longer makes me very happy. Ty for guide.
