Unfortunately, changing a flat tire on a Segway Ninebot Max is a tough task.
Electric scooters are machines, and they, like other vehicles need servicing and maintenance to ensure they run smoothly for a long time.
If you need to replace the front tire of your Segway Ninebot Max scooter follow this guide.
Remove the cap and reflection tag using a slotted screwdriver.
Use 3 mm Allen key to loosen three hexagon screws from each side of the wheel.
Snap the covers away from the scooter from both sides.
To detach the brake, use a 10 mm Allen wrench to remove the bolt from the tire that is attached with the brake.
Use a 15 mm socket wrench to remove 15mm bolt from the tire of the scooter on both sides of the front wheel.
Pull down the tire and remove it from the frame.
