Segway Ninebot Max Battery Replacement
  1. Segway Ninebot Max Battery Replacement, Remove the base plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Segway Ninebot Max Battery Replacement, Remove the base plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the scooter upside down and unscrew the 18 screws holding the base plate using a Security Torx T15 screwdriver.
    My Ninebot G2 Max had some of the adhesive melted onto the plate which made it stick when I tried to lift it off. With a painters tool / pry bar I gently worked the plate off. It was by the back 4 screws. Mainly by the pair that are 2nd from the back. (Not counting the single screw at the end)
    preynoso89 - crwdns2934203:0crwdne2934203:0
  2. Segway Ninebot Max Battery Replacement, Remove the old battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Segway Ninebot Max Battery Replacement, Remove the old battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 10 screws that hold the battery onto the frame and remove the battery from the enclosure.
    • Unplug any connectors that connect the battery and scooter together.
    @ademirfigu21839 ,
    Olá! Sim, é possível alterar o idioma no site da iFixit.
    Para mudar para o português, siga estes passos:
    1. Acesse ifixit.com.
    2. No canto superior direito da página, ao lado do ícone do perfil, clique no ícone de idioma (pode aparecer como “EN” para inglês).
    3. Selecione Português na lista de idiomas disponíveis.
    Depois disso, o site será exibido em português. Se precisar de mais ajuda, é só avisar!
    Kris Rodriguez -
  3. Segway Ninebot Max Battery Replacement, Place the new battery inside: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the new battery inside the enclosure and reinstall the 10 screws (if needed), bonding the battery to the scooter.
    What battery was used for this replacement?
    Renan - crwdns2934203:0crwdne2934203:0
  4. Segway Ninebot Max Battery Replacement, Connect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Segway Ninebot Max Battery Replacement, Connect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect the pins from the battery and scooter together.
    • Make sure to tuck in the wiring.
  5. Segway Ninebot Max Battery Replacement, Test the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn on the scooter and accelerate to make sure there are no errors and the scooter is running.
  6. Segway Ninebot Max Battery Replacement, Reattach the base plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Segway Ninebot Max Battery Replacement, Reattach the base plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Line up the base plate and tighten it with all 18 screws using a Security Torx T15 Allen Key.
crwdns2935229:08crwdne2935229:0
sunny sanghera
crwdns2935283:005/14/21crwdne2935283:0
278 crwdns2915208:0crwdne2915208:0
York University, Team S1-G24, O'Regan Summer 2021 crwdns2935289:0York University, Team S1-G24, O'Regan Summer 2021crwdne2935289:0
YORK-O'REGAN-SU21S1G24
Do you know where I can purchase a replacement battery for the Ninebot Max? I can't seem to find one.
Chip Bates - crwdns2934203:0crwdne2934203:0
If you find a new battery will you put me onto it aswell I need one do you know how much they are thanks in advance
Andrew Leslie -
Do you guys recommend purchasing any brand battery charger for your Ninebot Segway Scooter 🛴 or should I stick with the actual "Segway" brand charger from their official site??? Is there really a difference or is one just as good as the other???
Jessica Loftis - crwdns2934203:0crwdne2934203:0
looking for battery for ninebot zing e10 scooter
Isaac L - crwdns2934203:0crwdne2934203:0
Am o problema, când bateria trotinete ajunge la jumate se oprește, un răspuns va rog!
Gabi Gabrieluu - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 52
crwdns2936753:07crwdne2936753:0 375
crwdns2936753:030crwdne2936753:0 1,640
crwdns2942667:0crwdne2942667:0 45,784
