Sega Saturn Power Supply Replacement
  1. Sega Saturn Power Supply Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sega Saturn Power Supply Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
  2. Sega Saturn Power Supply Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
  3. Sega Saturn Power Supply Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the ESD safe tweezers to pull the battery out of its slot.
  4. Sega Saturn Power Supply Replacement, Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement, Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement, Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
  5. Sega Saturn Power Supply Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over so it rests right side up.
    • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
  6. Sega Saturn Power Supply Replacement, Power Supply: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sega Saturn Power Supply Replacement, Power Supply: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the power button plug on the power supply board. Use the iFixit opening tool if necessary.
  7. Sega Saturn Power Supply Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two black 11.4mm standoff screws on the back of the Sega Saturn holding the power socket in place. These screws are tight and easily stripped, so it's suggested to use a standoff screw head.
  8. Sega Saturn Power Supply Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the metallic 12.3mm JIS#1 screw holding down the power supply board.
  9. Sega Saturn Power Supply Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Power Supply Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the power supply board out of its socket, minding the pins that connect it to the motherboard. Some force will be required, but be careful when lifting or shaking the power supply board out.
Jan Ulloa
crwdns2935283:010/15/19crwdne2935283:0
630 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G6, Leahy Fall 2019 crwdns2935289:0USF Tampa, Team S1-G6, Leahy Fall 2019crwdne2935289:0
USFT-LEAHY-F19S1G6
crwdns2935297:018crwdne2935297:0
Incomplete. This is "Removal" only. "Replacement" indicates that there is a replacement part. Where is the replacement part? Where do you obtain/purchase it? No description of the replacement part or link to obtain it. Clarify.
BGPhilbin - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 151
crwdns2942667:0crwdne2942667:0 6,955
