Sega Saturn Disc Reader Replacement
  1. Sega Saturn Disc Reader Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sega Saturn Disc Reader Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
  2. Sega Saturn Disc Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
  3. Sega Saturn Disc Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the ESD safe tweezers to pull the battery out of its slot.
  4. Sega Saturn Disc Reader Replacement, Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement, Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement, Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
  5. Sega Saturn Disc Reader Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over so it rests right side up.
    • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
  6. Sega Saturn Disc Reader Replacement, Disc Reader: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not touch the laser reader, as smudges have been reported to ruin it.
  7. Sega Saturn Disc Reader Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull firmly on the ribbon cable from the end on the motherboard.
    • Don't worry about pulling it out of its socket; it can be plugged back in.
  8. Sega Saturn Disc Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the second cable out of its socket on the disk reader with the iFixit opening tool or ESD safe tweezers. When the lip of the cable gets enough distance out of the socket, it can be wiggled free.
  9. Sega Saturn Disc Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the laser reader slowly out of its slot hosted by these four pins. There is a screw underneath with a cable attached to the motherboard.
  10. Sega Saturn Disc Reader Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Saturn Disc Reader Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the metallic 12.2mm JIS #1 screw. This will need additional hands in reverse to hold the disk reader steady.
    • Remove the yellow tape on the reader strip and gently remove the disc reader without touching the laser reader.
Jan Ulloa
crwdns2935283:010/15/19crwdne2935283:0
630 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G6, Leahy Fall 2019 crwdns2935289:0USF Tampa, Team S1-G6, Leahy Fall 2019crwdne2935289:0
USFT-LEAHY-F19S1G6
crwdns2935297:018crwdne2935297:0
For the last step, it's quite a bit easier to remove (and put back) the top screw of the silver conductive strap from the top side of the CD drive instead of trying to remove the bottom screw, which is sorta tricky :)
Ming - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 8,363
