In this guide we dissassemble the Sega Master System II
crwdns2936621:0crwdne2936621:0
Take out the 5 screws at the bottom
Remove the 5 screws (3 at the back and 2 on the front)
Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
Remove the 2 screws thats holding the cartridge slot down
Congratulations! You have opened your Sega Master System Model 2!
Screenshots taken from a video by Global Garage
This is in the wrong section.
Nope, its in the Sega Master System area.
Krisow -
Not a Master System
