Sega Game Gear Case Replacement
  1. Sega Game Gear Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Case Replacement, Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
    It says remove 7 Philips screws, the picture shows 6 but one is incorrect.
    The thread below the label has no screw, but there is another one in the other battery compartment.
    The hole below the label is for a security bolt when stores put them on display.
    rs.beast - crwdns2934203:0crwdne2934203:0
    The screw hole in the bottom center is for the PowerBack. Also there are not 7 screws there are only 6
    Electrohacker - crwdns2934203:0crwdne2934203:0
  4. Sega Game Gear Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sega Game Gear Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sega Game Gear Case Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sega Game Gear Case Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully unplug the 2 white-tipped connectors on the top cover.
    Il faut aussi débrancher le connecteur du haut parleur (2 broches, en haut à droite).
    Arnaud Melun - crwdns2934203:0crwdne2934203:0
    There is a third cable on the right side of the top half in this picture which is the speaker. Unplug that too.
crwdns2935229:09crwdne2935229:0
Lauren Thurston
crwdns2935283:004/15/10crwdne2935283:0
469 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 28-33, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 28-33, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S28G33
crwdns2935297:019crwdne2935297:0
Is this guide made to help replacing the Game Gear shell? Almost doesn't seem like a thorough guide, I'm still seeing screws on the motherboard in the last photo, I assume those get taken out too?
Alex Tomalty - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 20,755
