Is your old circular saw motor just not running well anymore? This guide will help you to remove that pesky old motor and install a new one.
To ensure that you do not get grease and dirt on your table or floor, lay a towel down before you begin working.
With your Phillips screwdriver, unscrew all 7 of the 20 mm screws on the handle of the circular saw.
Unscrew the forked screw head
Lift off the top half of the handle.
Unscrew the two wide-head 20 mm screws holding the remaining half of the handle to the motor.
Remove the remaining half of the handle from the motor by lifting it over the screw that is keeping it in place.
Using a crescent wrench, unscrew the hex washer head screw that is holding the blade in place.
Lift the blade over the internally threaded screw and pull it off of the saw.
Remove the blade cover by applying upward pressure until it unsnaps from the washer.
Unscrew the 70 mm screw that is inside the black tube (see first picture).
Unscrew the five screws as highlighted in the second picture. The bottom left is a 70 mm screw and the other four are 20 mm screws.
The motor will now be loose and you should be able to twist the motor in a counter-clockwise direction until it is able to be pulled off.
