If your touch screen is broken, cracked or defective, use this guide to replace a broken screen on your Samsung Galaxy A50 (SM-A505F).
For your information, the screen product codes of a Samsung Galaxy A50 are: GH82-19204A or GH82-19713A.
'Before disassembling your phone, it is advisable to discharge the battery of the Samsung Galaxy A50 below 25%.' Otherwise, if you accidentally puncture or damage the battery during repair, the battery may catch fire or explode. These risks are lessened if the battery is mostly discharged.
Note: Replacing the screen includes removing the back of the phone, which means you will need a new piece of back adhesive.
If you damage the frame, you will need to replace it, as a damaged frame could result in uneven pressure on the screen, permanently damaging or destroying it.
Eject sim card tray
crwdns2935267:0crwdne2935267:0Suction Handle$2.99
Heat the back of the phone for 5 minutes at 65°C
Slowly lift the back glass off the phone using a suction cup
Insert a pick into the gap created.
Slide the pick around the edge, using more picks to keep the gap open.
Carefully remove the rear glass and set it aside.
crwdns2935267:0crwdne2935267:0Spudger$3.99
Remove all the screws using a 4mm Philips #00 screwdriver
Slide a spudger in between the screen and the frame
Slide the spudger around the entire perimeter of the phone to unclip the screen and separate it from the midframe
Separate and remove the midframe
Disconnect the battery
Unscrew the Phillips screw holding the motherboard
Disconnect cables 1 and 2
Unplug and remove the front camera (FaceTime)
Disconnect the blue and white coaxial cables
Gently remove the motherboard by lifting it up.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Using Tweezers, remove the vibrator
Remove the speaker that way as well
Remove the two Phillips screws, unplug and remove the fingerprint sensor.
Remove the charging board
Pull out the coaxial cables
Carefully remove the battery with a Spudger
Now you should have removed all the components in the phone (see picture)
Replace all the components in the new display frame according to the diagram to the right (bottom is fully assembled)
Clip the frame back onto the screen
Tighten all the screws
Using a new piece of tape, stick the glass back on
After receiving your new screen, you will need to remove the protective film from it before installing it.
To reassemble your device, follow the steps above in reverse.
Turn on your phone and test your repair before applying the new adhesive and closing the phone.
crwdns2935229:016crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2944067:06crwdne2944067:0
Merci, c’est réparé !
il me semble que le backcover du a50 est en plastique, le chauffer trop fort risque de le deformer
Effectivement une température de 65°C environ pendant 5 minutes suffira pour ramollir le sticker située sous la plaque arrière.
Does anyone know if the A505 screen and frame are the same for all variants?
Done, finger print sensor won’t work any more, everything else is.
