This guide demonstrates how to safely remove and replace the stand and stand accessories for the Sceptre X9 Komodo VII monitor.
Before you begin, ensure the monitor is powered off and unplugged, and that you’re working on a soft, flat surface to prevent screen damage.
Note: You may need to replace your stand if it’s broken, wobbly, or if you plan to mount your monitor using a VESA wall mount.
Caution: Avoid overtightening screws or applying too much force when removing parts; this could crack the plastic or damage internal components.
This repair takes only a few minutes and requires minimal tools. Please follow the steps below to finish the replacement safely and efficiently.
Power off and unplug the monitor before starting.
Place the monitor face down on a soft, flat surface (such as a towel) to protect the screen.
Using a Phillips #2 screwdriver, remove the four 11.5 mm screws securing the stand.
Gently pull the stand out to detach it from the monitor. - Caution: Do not force the stand out. If it resists, check that all screws have been fully removed before pulling.
Using the same Phillips #2 screwdriver, remove the two 11.5 mm screws securing the plastic bar.
Lift the bar away and set it aside.
Align the new stand and/or accessories with the mounting points on the back of the monitor.
Reinsert and tighten all screws securely.
Confirm the stand is stable and level before turning the monitor upright. - Reminder: Double-check all screws are firmly tightened and parts are properly aligned to prevent instability or tilting after reassembly.
