Sceptre X9 Komodo VII Speakers Replacement
  1. Sceptre X9 Komodo VII Speakers Replacement, Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off and unplug the monitor before starting.
    • Place the monitor face down on a soft, flat surface (such as a towel) to protect the screen.
    • Using a Phillips #2 screwdriver, remove the four 11.5 mm screws securing the stand.
    • Gently pull the stand out to detach it from the monitor. - Caution: Do not force the stand out. If it resists, check that all screws have been fully removed before pulling.
  2. Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same Phillips #2 screwdriver, remove the two 11.5 mm screws securing the plastic bar.
    • Lift the bar away and set it aside.
    • Align the new stand and/or accessories with the mounting points on the back of the monitor.
    • Reinsert and tighten all screws securely.
    • Confirm the stand is stable and level before turning the monitor upright. - Reminder: Double-check all screws are firmly tightened and parts are properly aligned to prevent instability or tilting after reassembly.
  3. Sceptre X9 Komodo VII Speakers Replacement, Board Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Speakers Replacement, Speakers: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two connectors to the speakers by gently pulling on the hard plastic straight up.
  7. Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel the tape from the board.
  8. Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the monitor so the screen is facing you.
    • Using Phillips #2 screwdriver remove the four 6.25 mm screws securing the speakers:
  9. Sceptre X9 Komodo VII Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the speakers up.
Xenia Leon Rodriguez
crwdns2935283:009/26/12crwdne2935283:0
37 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-56, Forte Fall 2012 crwdns2935289:0Cal Poly, Team 16-56, Forte Fall 2012crwdne2935289:0
CPSU-FORTE-F12S16G56
crwdns2935297:013crwdne2935297:0
crwdns2942667:0crwdne2942667:0 505
