Power off and unplug the monitor before starting.
Place the monitor face down on a soft, flat surface (such as a towel) to protect the screen.
Using a Phillips #2 screwdriver, remove the four 11.5 mm screws securing the stand.
Gently pull the stand out to detach it from the monitor. - Caution: Do not force the stand out. If it resists, check that all screws have been fully removed before pulling.
Using the same Phillips #2 screwdriver, remove the two 11.5 mm screws securing the plastic bar.
Lift the bar away and set it aside.
Align the new stand and/or accessories with the mounting points on the back of the monitor.
Reinsert and tighten all screws securely.
Confirm the stand is stable and level before turning the monitor upright. - Reminder: Double-check all screws are firmly tightened and parts are properly aligned to prevent instability or tilting after reassembly.
Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
Pry the monitor using the plastic opening tool to release the clips holding the cover on.
Once all the clips have been released, remove the cover by pulling it up.
Using the #2 Phillips screwdriver, remove the one 6mm screw.
Unplug the indicated cable by pulling on the base.
Slide the cover toward the top of the monitor.
Remove the cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the two connectors at the top-left of the power board.
Disconnect the two connectors at the very bottom of the power board (pink wire).
Disconnect the multi-pin connector at the top of the motherboard.
Use a #2 Phillips to unscrew the two 4.5mm screws on each side of the back panel.
Carefully side the connectors through their respective openings.
Lif the back panel to reveal the LCD back cover.
Use a #2 Phillips to remove the four 6mm screws on the bezel for each side of the back cover.
Remove the bezels from the LCD back cover (the bezels should simply fall off once the screws are removed).
Use a #0 Phillips to remove the three 4.5mm screws located on the LCD back cover.
Lift the inner panel to remove it.
Disconnect the muti-pin connector on the LCD back cover by firmly pulling down on it.
Use a #0 Phillips to remove the two 6mm screws on each side of the LCD cover.
There are tabs holding down the cover. You may have to use a bit of force to pry them open.
A small flat-blade screwdriver can be used to pry off LCD cover.
Lift the LCD back cover to reveal the LCD screen below.
