Unscrew and remove the base of the machine.
Unscrew the lid for the water opening, and take out the screws holding the metal canister in place.
Take out the screws holding the metal canister in place from the inside.
Remove the dial from the side of the machine to allow separation from the plastic hull (this step will require breaking it off with a hammer).
Remove the internal components from the outer shell (this step will require cutting the plastic tubes connecting the canister to the hull).
The switch, connected to the power source, connects to the fuses and then directly to the metal canister. From there it connects to the light indicating whether the device is being heated and to the temperature sensor, which is also connected directly to the metal canister and back to the power source.
Disclaimer: Disassembly of this device requires the partial destruction of the device. To reassemble your device, follow these instructions in reverse order.
I’m curious to know whether the straw inside the water reservoir is plastic, or silicone?
