The only complication with this replacement is that the keyboard ribbon cable is taped down and can't be easily removed without partially removing the motherboard.
Remove the battery
Remove every screw on the underside of the laptop chassis
Once the screws are removed, using a flat tool, prise open the bottom of the case from the sides, following around the edges of the laptop until the bottom pulls off entirely.
Accessible replaceable parts include:
DVD Drive
Memory
LCD screen
SSD
WiFi Network card
CPU Fan
Keyboard
The keyboard cable is visible immediately on opening the laptop, but there's an annoying hitch: Toshiba have taped it to the metal underneath the motherboard.
As a result, the motherboard will need moving enough to pull off the tape.
So to start, disconnect all the ribbon cables that aren't free-moving on one end. These are:
2 x USB controller cables
1 x trackpad cable
1 x Keyboard cable
1 x audio ports controller cable
Remove the following screws holding down the motherboard:
2 x DVD bay screws
1 x next to the WiFi card
1 x CPU fan screw
1 x next to the audio port controller
After removing the screw, disconnect the fan cable
Pull the fan clear of the motherboard so it can be moved further
Lift the motherboard near the keyboard cable. It should now be free enough to see the tape holding the keyboard cable attached
Remove the tape
Carefully turn the laptop over
It may be easier to put the bottom of the chassis back on lightly so unsecured parts don't tip out.
The keyboard is clipped into the chassis. Starting at the sides of the keyboard, prise the keyboard out of the clips, moving around the keyboard until the keyboard easily pulls out.
Having removed the tape, the keyboard cable should now pull through from the rear easily.
Don't forget to replace the removed screws and reinsert all cables, including the CPU fan cable.
