Satechi Aluminum Keyboard Disassembly
    • The power switch is located above the numpad on the vertical side of the keyboard
  1. Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber feet (they are simply glued in place)
    • Use a heat source to soften the adhesive that holds down the bottom plate
    • Check the pictures to see where the adhesive is applied inside the device
    • Use a plastic pick or some other tool to cut through the adhesive
    • Remove the bottom plate
  2. Satechi Aluminum Keyboard Disassembly, Removing the top cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Satechi Aluminum Keyboard Disassembly, Removing the top cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Satechi Aluminum Keyboard Disassembly, Removing the top cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In order to get to the electronics inside we have to first remove the aluminium top cover
    • This is necessary because the plastic with the electronics underneath is clued to the top cover and is not removable without removing the clue
    • To remove the top cover first check out the images to see where to adhesive is applied on the cover
    • Use some heat source to soften the adhesive
    • Use a plastic pick or some other tool to cut through the adhesive (if the adhesive is really soft then simply applying pressure to the keycaps can help remove the cover)
    • Remove the cover
  3. Satechi Aluminum Keyboard Disassembly, Remove plastic cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Satechi Aluminum Keyboard Disassembly, Remove plastic cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Satechi Aluminum Keyboard Disassembly, Remove plastic cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start by removing the twelve Phillips #00 screws marked in the picture
    • Now you should be able to lift the plastic cover
  4. Satechi Aluminum Keyboard Disassembly, Battery close up: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wisdom here.
Freeness2359
crwdns2935283:008/30/23crwdne2935283:0
129 crwdns2915208:0crwdne2915208:0
followed steps in order to fix the issue of slamming letter Y. Lots of adhesive confirmed for model ST-AMBK.
For all who seek - RTM if possible.
It is controller issue.
Myke S. - crwdns2934203:0crwdne2934203:0
It should be illegal to make electronics this hard to disassemble.
robinbennich - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 1,532
