Sanyo VPC-X1200 flash replacement
  1. Sanyo VPC-X1200 flash replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sanyo VPC-X1200 flash replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sanyo VPC-X1200 flash replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 flash replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 flash replacement, LCD Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo VPC-X1200 flash replacement, LCD Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 flash replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo VPC-X1200 flash replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 flash replacement, Button Plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo VPC-X1200 flash replacement, Button Plate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 flash replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo VPC-X1200 flash replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  7. Sanyo VPC-X1200 flash replacement, Lens Unit: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  8. Sanyo VPC-X1200 flash replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo VPC-X1200 flash replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three silver screws.
    • Three 5.5mm screws
  9. Sanyo VPC-X1200 flash replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
  10. Sanyo VPC-X1200 flash replacement, Flash Lens: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sanyo VPC-X1200 flash replacement, Flash Lens: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sanyo VPC-X1200 flash replacement, Flash Lens: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 4 screws attached to the exterior silver bezel.
    • Four 3.5mm screws
  11. Sanyo VPC-X1200 flash replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove round silver bezel from the front of the camera.
  12. Sanyo VPC-X1200 flash replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws on the bottom of the front cover.
  13. Sanyo VPC-X1200 flash replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove tripod mount.
  14. Sanyo VPC-X1200 flash replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift off the front cover plate of the camera.
  15. Sanyo VPC-X1200 flash replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the flash lens using the spudger or a finger.
    • It will be attached by a piece of tape, peel the lens off of that piece of tape without removing the tape.
Anthony Giardina
crwdns2935283:004/19/10crwdne2935283:0
20 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-10, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 7-10, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S7G10
crwdns2942667:0crwdne2942667:0 2,246
