Sanyo VPC S1275 LCD Screen Replacement
  1. Sanyo VPC S1275 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 LCD Screen Replacement, Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sanyo VPC S1275 LCD Screen Replacement, Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sanyo VPC S1275 LCD Screen Replacement, Case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  8. Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
    • Place the LCD screen on a non-abrasive surface.
  9. Sanyo VPC S1275 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger lift the black flap up to release the ribbon cable.
    • The LCD screen will now be completely detached from the camera.
Evan Perez
crwdns2935283:004/15/10crwdne2935283:0
19 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-24, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 24-24, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S24G24
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,194
