Sanyo SCP-8100 Keypad Replacement
    1. Sanyo SCP-8100 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
      • Lift and remove the battery from the back of the phone.
    1. Sanyo SCP-8100 Keypad Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a push pin, pull out the plug on the back, located under the antenna.
      • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
    2. Sanyo SCP-8100 Keypad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
    3. Sanyo SCP-8100 Keypad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to pry the back panel along the edges.
      • You may need to apply some force when prying.
    4. Sanyo SCP-8100 Keypad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • While removing the back panel, take out the rubber cover on each side.
    1. Sanyo SCP-8100 Keypad Replacement, Keypad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement, Keypad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the volume and camera buttons off from the side of the phone.
    2. Sanyo SCP-8100 Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the gray frame covering the charging port from the bottom of the phone.
    3. Sanyo SCP-8100 Keypad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the opening tool to lift the motherboard up from the phone.
      • Be careful and pry the motherboard off slowly. The motherboard will be attached to the phone at the top by a metal ribbon.
    4. Sanyo SCP-8100 Keypad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sanyo SCP-8100 Keypad Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip open the phone, exposing the keypad.
      • Use the opening tool to push the buttons from the bottom to lift the rubber keypad up.
      • Pull the keypad out of the phone.
Irenz Afable
crwdns2935283:004/15/13crwdne2935283:0
57 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-41, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 10-41, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S10G41
crwdns2935297:042crwdne2935297:0
crwdns2942667:0crwdne2942667:0 687
