Follow these guides to properly remove and install a new earpiece on the Sanyo SCP-8100. If you cannot hear anything during calls or the sound quality is not clear, then you may need to replace the earpiece.
You will need to open the top panel by pulling out four stickers that hides the four screws.
- Note: You will need to use a push pin to pull out the stickers. Using a spudger or an opening tool will not be sufficient enough. They are too thick to use and will make it difficult to use.
Open the phone and remove the four stickers that hide the four 0.5 mm screws.
On the bottom two, use a push pin to pull out the stickers.
For the top two, use the same push pin and gently pull out the stickers.
Use the Tri-Wing Y1 screwdriver to unscrew the now uncovered four 0.5 mm screws.
Use the opening tool to pry open the front panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to detach the plastic connector.
With the tweezers, pull the wires from the plastic clamp.
Use the opening tool to pull the earpiece off of the top panel.
