Removing the outer front case of the phone will reveal the LCD component of the device. The case can be swapped out with another of a the same or a different color.
With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
Carefully pry the screen protector off the phone using the flat end of the spudger.
Once free from the adhesive, pull the screen protector away from the phone.
Use the spudger to pry off the front case from the left and right sides of the device.
Once it has popped off, pull the casing apart with fingers.
