Sansa e260R Scroll Wheel Replacement
  1. Sansa e260R Scroll Wheel Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Scroll Wheel Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Scroll Wheel Replacement, Front Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Scroll Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sansa e260R Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sansa e260R Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the bottom of the black button to remove it from the device.
  9. Sansa e260R Scroll Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sansa e260R Scroll Wheel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  10. Sansa e260R Scroll Wheel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
JenniferW
crwdns2935283:001/31/12crwdne2935283:0
194 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-15, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 8-15, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S8G15
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,505
