Sansa e260R Front Panel Replacement
    1. Sansa e260R Front Panel Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Before disassembling the device, make sure it is powered off.
      • Remove the four 1.5mm screws on the back of the device.
    2. Sansa e260R Front Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a plastic opening tool, lift the metal backing from the front of the device.
    3. Sansa e260R Front Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the rear panel off of the Sansa e260R.
    1. Sansa e260R Front Panel Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
    1. Sansa e260R Front Panel Replacement, Front Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 1.5mm screws on the inner casing of the device.
      • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
    2. Sansa e260R Front Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the device so that the front is facing you.
      • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
    3. Sansa e260R Front Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sansa e260R Front Panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the front cover away from the rest of the device.
Casey Smith
crwdns2935283:001/20/12crwdne2935283:0
111 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-15, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 8-15, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S8G15
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 2,412
