To replace a faulty microphone follow the steps in this guide. This may be your only option if you find yourself unable to make voice recordings anymore with your device.
Remove the cover of the battery compartment.
Remove the battery from the inside compartment.
Locate and remove the screw near the battery compartment.
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
Push the battery contact springs down through the hole because the springs may prevent the case from separating.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
Now you can see and access all components found inside the device!
Locate microphone on motherboard.
Find where microphone is connected to motherboard via solder.
Use the soldering iron to liquefy the solder connecting the microphone to the motherboard.
When not in use, be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
Remove the faulty microphone as you heat and melt the soldering points.
Replace the faulty microphone with a new one in working order.
With the new microphone in place, use the soldering iron and solder to create a stable connection between the motherboard and microphone.
Give the new solder time to cool and harden.
