This guide can be used for those that are experiencing difficulties with the hold switch on their Sandisk Sansa m230 Series mp3 player. A faulty hold switch may cause the device to fail to turn on. Use this guide to replace a faulty hold switch.
Remove the cover of the battery compartment.
Remove the battery from the inside compartment.
Locate and remove the screw near the battery compartment.
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
Push the battery contact springs down through the hole because the springs may prevent the case from separating.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
Now you can see and access all components found inside the device!
Locate the hold switch on the motherboard.
Locate the hold switch connection to the motherboard via soldered connections.
Use the soldering iron to liquefy the solder connecting the hold switch to the motherboard.
Liquefy the solder on each contact and remove each contact individually.
With the contacts removed, lift the switch off the motherboard.
Replace the faulty hold switch with a new one.
With the new hold switch in place, use the soldering iron to solder the contacts between the motherboard and hold switch.
Be sure to allow the new solder to cool and harden.
