SanDisk Sansa C250 Front Case Cover Replacement
  1. SanDisk Sansa C250 Front Case Cover Replacement, Battery Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SanDisk Sansa C250 Front Case Cover Replacement, Battery Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the back cover toward the top of the device with your thumb to remove it.
  2. SanDisk Sansa C250 Front Case Cover Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your plastic pry tool under the edge of the battery.
  3. SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift up with the pry tool. The battery should lift up and out.
  4. SanDisk Sansa C250 Front Case Cover Replacement, Rear Case Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips head screwdriver, remove the two black .265" screws at the base of the device.
  5. SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two plastic arms of the case cover, near the middle of the device.
    • Using the plastic ply tool, pry up the two arms of the case to free them from the sides.
  6. SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the rear case cover toward the top of the device with your thumb to release it, and remove it from the device.
  7. SanDisk Sansa C250 Front Case Cover Replacement, Front Case Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  8. SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
  9. SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the case cover starting on the side most distance from the buttons.
  10. SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  11. SanDisk Sansa C250 Front Case Cover Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now safely remove the front case cover from the device.
Nicolas Coffey
crwdns2935283:001/27/12crwdne2935283:0
58 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-30, Amido Winter 2012 crwdns2935289:0Cal Poly, Team 3-30, Amido Winter 2012crwdne2935289:0
CPSU-AMIDO-W12S3G30
crwdns2942667:0crwdne2942667:0 1,452
