This guide shows how to remove and replace the water filter in your Samsung refrigerator.
The water filter purifies the water that's dispensed at the door or used to make ice. If your water filter replacement light is blinking or your water tastes strange, you may need to replace your water filter.
If you have trouble removing the filter, there may be water pressure build up. Run the water for a few seconds to relieve the pressure and try again.
This guide will work for most Samsung Refrigerators. This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Open both French doors for the refrigerator compartment.
Locate the water filter.
Twist the water filter cap counter-clockwise until it's loosened from its housing.
Pull the water filter straight out of its housing and remove it.
Run the water to flush the filter and check for leaks for a few minutes.
Press reset on the filter indicator.
IS there a difference from the HAF-QIN and the HAF-QIN/EXP
Does anyone have instructions on taking out the filter assembly to find where leaks are coming from?
