Turn watch faced down to reveal the screws. Remove the straps by pulling on pin switches to release.
Use the tin metal pry tool to gently penetrate the back.
Use the metal pry tool as support for the opening blue pick
Gently Lift the back to reveal a connector, use a tweezer to remove it then you will have access to the back
Separate back fully from rest of the body
use tweezer to remove all 3 connectors and remove the screw
Use Spudger to lift panel housing from body
Lift off motherboard and use tweezer to lift up bettery connector from the plastic housing
use spudger to lift battey out of plastic housing
Separate battery from the plastic body, then install replacement battery
crwdns2935229:05crwdne2935229:0
I have so benefited from this portal , I have now made my own contribution. Hope it helps someone.
Jimi Aloba - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Excellent guide Haven't done it yet. Where can I find the battery for this watch, also what type of screwdriver are you using for the 1st 4 screws? None of mine fit it.
mnmacd - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
