Samsung WB850F Lens Assembly Replacement
  1. Samsung WB850F Lens Assembly  Replacement, Control Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB850F Lens Assembly  Replacement, Control Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB850F Lens Assembly  Replacement, Control Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Lens Assembly  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Lens Assembly  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB850F Lens Assembly  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
  4. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two screws.
    • Gently pry open metal case using Plastic tool openers.
  5. Samsung WB850F Lens Assembly  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB850F Lens Assembly  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the lens connector chip to remove the lens.
  6. Samsung WB850F Lens Assembly  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
Jousling Vazquez
crwdns2935283:002/08/16crwdne2935283:0
431 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-4, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 12-4, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S12G4
hi I have problem...could you please help me with my camera samsung wb850f
merdaneliyev - crwdns2934203:0crwdne2934203:0
I am forward to hearing from you....
crwdns2942667:0crwdne2942667:0 1,690
