crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Samsung WB690crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Samsung WB690 + Lens Teardown, Remove the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Remove the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Remove the battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery by pressing in the blue tab.
  2. Samsung WB690 + Lens Teardown, Remove the screws holding in the front panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Remove the screws holding in the front panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Remove the screws holding in the front panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 5 Philips #0 screws in total.
  3. Samsung WB690 + Lens Teardown, Pry open the front cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Pry open the front cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Pry open the front cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, ensure the cover is at least mostly unclipped on all sides.
    • Then, focus on fully popping off the front cover. Prying in the position shown above the battery cover is the most consistently effective. You may need to use a bit more force for this step.
  4. Samsung WB690 + Lens Teardown, WARNING: The flash capacitors can shock you if not properly discharged: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful not to touch the capacitors or the internals of the camera.
    • Even if the battery has been removed, the capacitors likely still hold a charge, enough to give you a nasty shock.
  5. Samsung WB690 + Lens Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Showing how the clips line up
  6. Samsung WB690 + Lens Teardown, Discharge the capacitors using a multimeter: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Discharge the capacitors using a multimeter: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Discharge the capacitors using a multimeter: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set your multimeter to the highest voltmeter setting (e.g. 600V on the one shown) and ensure the probes are connected to the correct terminals.
    • Connect the red probe to the solder on the red wire and the black probe to the solder on the black wire.
    • WARNING: Be careful not to touch the two probes together while doing this. It would short-circuit the capacitor and dump a large amount of charge very quickly. Also be careful not to touch the metal on the probes.
    • Look at the meter reading. It could start in the >300V range. If you don't see a reading, make sure the probes are making a good connection. If they are, and you still don't see a reading, drop the voltmeter setting a couple of notches (e.g. to 20V) and try again. The capacitors may already be (mostly) discharged.
    • You should see the voltage dropping as the capacitor discharges through the multimeter.
    • Continue to discharge until the voltage reduces to a significantly lower level (e.g. <20V), then switch to a more sensitive voltmeter setting (e.g. 20V) to maintain accuracy and continue discharging.
    • Discharge speed will slow down the lower the voltage gets. Once it slows to a crawl at a low voltage (<10V), you can intentionally short-circuit the capacitor with the probes to quickly discharge the remaining charge.
    • Verify the capacitors are fully discharged using the multimeter at a more sensitive setting (e.g. 2V). The reading should be at or close to 0V. Note: If the reading starts increasing it's because the multimeter is starting to charge the capacitors. Short-circuit them one last time and turn off the multimeter.
  7. Samsung WB690 + Lens Teardown, Start prying off the back cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Start prying off the back cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Start prying off the back cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As with the front cover, start prying off the back cover on all sides except the top
  8. Samsung WB690 + Lens Teardown, Pop off the back cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Pop off the back cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Pop off the back cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The trickiest part is corner by the HDMI cover. The arrow in the second image points to where the plastic cover is sandwiched between two other pieces. Don't apply extra force to the back cover until this clip is popped out.
  9. Samsung WB690 + Lens Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Popped back cover
  10. Samsung WB690 + Lens Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lining up cover.
  11. Samsung WB690 + Lens Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the board.
    • Flip it out of the way.
  12. Samsung WB690 + Lens Teardown, Remove the screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Remove the screen: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Remove the screen: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the ribbon cable with a pry bar.
    • Remove the screen. It might be slightly stuck on one side with glue, but it should come off without much effort.
    • Place it face down in the back case to protect the screen.
  13. Samsung WB690 + Lens Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw holding on the backplate.
  14. Samsung WB690 + Lens Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop off the backplate.
  15. Samsung WB690 + Lens Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put the backplate with the back cover to the side.
  16. Samsung WB690 + Lens Teardown: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The main board.
  17. Samsung WB690 + Lens Teardown, Unclip the main board ribbon cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Unclip the main board ribbon cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Unclip the main board ribbon cable: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the main board ribbon cable with a pry bar by pulling the black tab up and away from the cable.
    • Remove the ribbon cable from the slot.
  18. Samsung WB690 + Lens Teardown, Unclip the CCD cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Unclip the CCD cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Unclip the CCD cable: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the CCD ribbon cable with the same method as the main board cable.
  19. Samsung WB690 + Lens Teardown, Unclip the lens cable: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Unclip the lens cable: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Unclip the lens cable: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the lens ribbon cable. Unlike the previous two, pull up and towards the cable.
  20. Samsung WB690 + Lens Teardown: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw holding in the main board.
    • Remove the main board, pulling up and away from where the ports are poking through. You may want to help unstick the ports by pushing on them from the outside at the same time.
  21. Samsung WB690 + Lens Teardown: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flipping over the main board.
  22. Samsung WB690 + Lens Teardown: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The lens is now free from the case.
  23. Samsung WB690 + Lens Teardown: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The lens module.
  24. Samsung WB690 + Lens Teardown, Begin lens disassembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Begin lens disassembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown, Begin lens disassembly: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the side ribbon cable.
    • WARNING: If your lens is currently working, there's a high chance the following steps will break it. There are a lot of moving parts and correct reassembly is tricky. Even if you do reassemble it correctly, you might introduce extra friction which will cause the lens to jam.
  25. Samsung WB690 + Lens Teardown: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the board from the plastic restraints. You will have to pull on the cable a bit.
  26. Samsung WB690 + Lens Teardown: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The back of the lens is now free.
  27. Samsung WB690 + Lens Teardown: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The focusing mechanism.
  28. Samsung WB690 + Lens Teardown: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The lens with optical image stabilisation (?)
  29. Samsung WB690 + Lens Teardown: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This gear connects the motor to the zoom mechanism.
  30. Samsung WB690 + Lens Teardown: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the lens to remove it from the outside housing.
    • Note the alignment highlighted by the red boxes.
  31. Samsung WB690 + Lens Teardown: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The circled nubs follow the tracks on the inside of the housing, translating rotation into linear motion extending the lens outwards.
  32. Samsung WB690 + Lens Teardown: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the next layer.
  33. Samsung WB690 + Lens Teardown: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Track and follower alignment.
  34. Samsung WB690 + Lens Teardown: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  35. Samsung WB690 + Lens Teardown: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  36. Samsung WB690 + Lens Teardown: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  37. Samsung WB690 + Lens Teardown: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  38. Samsung WB690 + Lens Teardown: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  39. Samsung WB690 + Lens Teardown: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Layer alignment.
    • Most layers have a rotational symmetry of order 3 (i.e. they're identical after rotating them 120 degrees), but these layers have one correct orientation.
    • The circled parts of the two layers must align. Pushing the aligned layers together closes the outer lens cover.
  40. Samsung WB690 + Lens Teardown: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  41. Samsung WB690 + Lens Teardown: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB690 + Lens Teardown: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The last piece.
Jess
crwdns2935283:003/11/25crwdne2935283:0
553 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 245
