crwdns2959928:0crwdne2959928:0 ↓This guide will give user step by step instructions on how to replace the flash capacitor of the camera.
The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver.
Using the spudger, and plastic opening tool open the casing of camera.
Once you open the camera case, you will be able to work on any part of the camera.
Carefully take out the capacitor using the spudger.
Disconnect the wire from battery and replace the old battery with new battery.
Connect the wires to new battery and put the battery back in terminal.
