Samsung WB350F Menu/Control Buttons Replacement
crwdns2869540:0crwdne2869540:0: 2K
2
19
102
1,953
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
If your control/menu buttons aren't working on your camera, this guide will walk you through replacing them.
    1. Samsung WB350F Menu/Control Buttons Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement, Rear Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the wristlet strap.
      • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
    2. Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
      • There is one silver screw on the bottom and two black screws on each side.
      • Keep the screws together for an easier re-assembly later.
    3. Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Open the case of the camera using your plastic opening tool.
      • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
      • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
    4. Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the plastic casing, exposing the inner workings of the camera.
    1. Samsung WB350F Menu/Control Buttons Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement, Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
      • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
    2. Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Move the menu button panel to the right as well as the screen.
      • Be careful because each are connected to the camera by a ribbon.
    3. Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
    4. Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the silver panel.
    5. Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the screen back over.
      • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
    6. Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully detach both ribbons by gently pulling one at a time.
      • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
      • Be sure to pull gently as you do not want to break either ribbon.
    1. Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pull the ribbon in order to remove the menu/control button panel.
      • The ribbon isn't secured with a connector and you are able to pull it straight out.
Taylor Joubert
crwdns2935283:003/04/16crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 crwdns2935289:0UMass Dartmouth, Team 6-2, Bhusal Spring 2016crwdne2935289:0
UMASSD-BHUSAL-S16S6G2
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 102
crwdns2959996:0crwdne2959996:0 1,953
