Samsung WB2200F Flash Option Button Replacement
  1. Samsung WB2200F Flash Option Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the camera upside down on a hard surface such as a table. Make sure that the battery compartment is visible.
  2. Samsung WB2200F Flash Option Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the nob counter-clockwise while pushing cover to the left. Then pull the cover up to reveal the battery.
  3. Samsung WB2200F Flash Option Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the blue tab to the right to release the battery.
  4. Samsung WB2200F Flash Option Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully slide the battery out of the camera. It can then be replaced with a new battery.
  5. Samsung WB2200F Flash Option Button Replacement, Face-plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung WB2200F Flash Option Button Replacement, Face-plate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung WB2200F Flash Option Button Replacement, Face-plate: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
  6. Samsung WB2200F Flash Option Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
  7. Samsung WB2200F Flash Option Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
    • Make sure to not damage any of the electronic components of the camera
  8. Samsung WB2200F Flash Option Button Replacement, Flash Option Button: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Looking at the back of the exposed face plate, remove the four 5mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
  9. Samsung WB2200F Flash Option Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift off the metal cover.
  10. Samsung WB2200F Flash Option Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean out any dust or debris from the button interface.
    • Replace faulty button.
Rachelle
crwdns2935283:003/08/16crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-4, Landers Spring 2016 crwdns2935289:0UMass Dartmouth, Team 5-4, Landers Spring 2016crwdne2935289:0
UMASSD-LANDERS-S16S5G4
crwdns2942667:0crwdne2942667:0 379
