crwdns2959928:0crwdne2959928:0 ↓This guide will show you how to replace the lens assembly on the Samsung WB1100F. It will show you a step by step replacement guide of how to remove parts leading up to and including the lens successfully.
Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
Remove six 1.2 mm Phillips #00 screws from the side of the camera.
Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Flip the LCD screen over to reveal the display cable.
Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
Remove two 1.2 Phillips #00 screws connected to the motherboard.
Desolder five wires connected to the camera motherboard.
Use the tip of a spudger or your fingernail to flip up the small retaining flaps on the five ZIF connectors on the motherboard.
Detach the five ribbon cables from the camera motherboard.
Remove the three 1.5 mm Phillips #1 screws connected to the lens assembly.
Pull the lens assembly from main body of the camera, using a spudger to pry if necessary.
