This guide will assist users to replace a damaged or nonoperational jog button.
Start by removing the screen bezel.
Use a pair of spudgers to pry between the bezel and the rest of the monitor.
lay monitor on its back and pull off screen cover.
Flip the monitor over so that it is facedown.
remove the single screw in the middle using a #2 Phillips screwdriver.
Remove the backing to reveal the Jog Button.
Disconnect signal cable to power supply board.
Remove and replace jog button.
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
crwdns2947412:05crwdne2947412:0
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
Does anyone have the part number or where I can buy the new jog button?
“bn96-32135b “
this is the part number i found BN96-32135B
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
