Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
Remove the screw on each side of the device using a Phillips head screwdriver.
Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
Once the back cover has been removed the battery will be visible.
Pry the battery from the device.
Unplug the battery connecting cables.
Nice instructions. Any idea where I can purchase a new battery that will fit?
