Samsung S5230 Star.
How to dis-assembly and change the Touch Screen. Full video you ca see here:
crwdns2936621:0crwdne2936621:0
Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
Unstuck camera keys and remove the middle bezel.
Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
Now is easy to remove the touch screen.
Install new touch screen and assembly the phone.
crwdns2935229:010crwdne2935229:0
