Follow this guide if you want to replace the back cover of your Samsung Series 5 3G Chromebook. Removing the back cover exposes all the internal components of the laptop. Make sure your Chromebook is powered off before you begin.
Place the laptop on a flat surface with the bottom side facing up.
Remove the rubber feet from the bottom of the panel using your fingernails.
Remove all the seven screws from the bottom panel.
Loosen the back cover panel using a spudger.
Once you work your way around, you can remove the panel.
crwdns2917034:0crwdne2917034:0
If anyone was wondering about putting the shampoo in the same bag as your Chromebook…don't! I'm just going from the house to the man cave (maybe 100 feet). A couple hours later I remember charge the chrome…and F
