This guide demonstrates how to safely remove and replace the motherboard (logic board) in a Samsung SPH-M360 flip phone.
A motherboard replacement may be necessary if the phone has stopped powering on, frequently freezes, or has sustained liquid or impact damage that affects performance.
Before beginning this repair, make sure the phone is completely powered off and that you’re working on a clean, static-free surface to avoid electrical damage. You’ll need only a few basic tools and a careful touch to complete this process in under 20 minutes.
Caution: The logic board is delicate. Avoid using metal tools when prying or disconnecting cables to prevent short-circuiting or breaking connectors.
Note: You’ll need a Phillips #00 screwdriver and a plastic opening tool. A magnetic mat or tray is helpful for keeping screws organized during the process.
Detach the battery cover by sliding the cover down toward the bottom of the phone.
Lift up on the battery cover to complete cover removal.
Remove battery by lifting up in the corner of the battery.
Use a phillips head (PH) #00 screwdriver to remove four screws connecting the two halves of the case.
Using your plastic opening tool, pry under the back case starting with the top as marked by red circle.
The volume button and camera button are held in by the back case. Volume button pictured. Camera button opposite.
REASSEMBLY ONLY: Replace volume and camera buttons in place. Then, insert the top of the back case FIRST and squeeze together clips as you work toward the bottom of the phone.
Locate the ribbon at the top right corner of the logic board.
Use the opening tool to gently lift the ribbon away. It should lift easily.
During reassembly, align the gold contacts and black plastic ends, then press lightly until it clicks into place.
Insert the plastic opening tool beneath the logic board.
While stabilizing the phone, gently lift the board away from the casing. Please do NOT force it! If it resists, apply even pressure in multiple locations.
If you plan to reuse the logic board, store it in a clean, static-free environment to avoid dust and debris contamination.
