Replace a broken loud speaker.
Rotate the phone onto its front side so that the LCD screen is facing away from you.
Remove the battery by pressing down on the battery release button while sliding the battery downwards.
Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
Gently remove the logic board and LCD screen from the back cover of the phone.
Remove the two screws above the LCD screen with a Phillips #00 screw driver. These connect to the white plastic cover in which the speaker is housed located on the reverse side of the logic board.
Rotate the logic board so that the LCD screen is face down.
Gently begin to separate the white plastic cover from the logic board.
Locate the two wires (black and red) which connect the speaker to the logic board.
Using your nails, tweezers, or any precise grabbing tool, pinch the speaker connector (clear plastic plug that goes into the logic board) and pull gently. It should pop out easily.
Once the wires are disconnected and the screws removed, the white plastic cover can easily be removed from the logic board.
Use any small flat object to remove the speaker from the white plastic cover by wedging your tool between the speaker and the cover.
