The motherboard is the main electronic "heart" of the phone. Only proceed with this replacement if you have tried all other options to no avail.
Remove the back panel by pressing up on switch, located at the top on the back of the phone.
Unscrew the four 4.5mm screws located on the back plate.
Remove the rubber screw cover using your fingernail.
Unscrew the 4.5mm screw located underneath the rubber cover.
Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
With the back panel removed, the motherboard should be fully exposed.
Remove the camera and volume buttons and place them in a safe spot until reassembly.
Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
