Samsung SGH-A137 Motherboard Replacement
  1. Samsung SGH-A137 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your thumbs to pull down on the back cover to remove it and expose the battery.
  2. Samsung SGH-A137 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the indent in the case below the battery. (see red square)
    • Place your finger at the indent and pull up on the battery to remove it.
  3. Samsung SGH-A137 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung SGH-A137 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung SGH-A137 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the 4 screw holes and remove the 0.4 mm Phillips head screws using a #000 Phillips head screwdriver. (See red circles)
  4. Samsung SGH-A137 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, gently pry open the back of the phone at the seam.
    • Carefully work the tool all the way around the opening while prying up to avoid breaking the plastic retaining clips.
  5. Samsung SGH-A137 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SGH-A137 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Smaller press-fit connectors may require a simple flick with a plastic opening tool or spudger.
    • Place the flat edge of a spudger under the edge of the press-fit connector and , gently pry the connector straight up from its socket. (Highlighted by the red square)
  6. Samsung SGH-A137 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, gently pry up the motherboard.
    • You might need to pry from several different locations to get the motherboard loose enough to remove.
Gayle Eberhardt Mitchell
crwdns2935283:009/04/15crwdne2935283:0
652 crwdns2915208:0crwdne2915208:0
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 crwdns2935289:0USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015crwdne2935289:0
USFSM-STEWART-F15S1G1
crwdns2935297:020crwdne2935297:0
crwdns2942667:0crwdne2942667:0 741
