This guide will demonstrate how to replace your Samsung SGH A707 phone's motherboard. Over time or as a result of physical damage, the Samsung SGH A707 motherboard may need to be replaced. One sign your motherboard needs replacing is unresponsive keys.
Press on the markings on the cover and pull it down to reveal the battery.
Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
Here is the phone without the battery.
Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
Use the prying tool the pry off the phone's plastic frame.
Use the prying tool to disconnect the rectangular connector.
Use the prying tool to disconnect the small connector.
Here is the phone without the logic board.
