Samsung SCH-U340 Top Casing Replacement
  1. Samsung SCH-U340 Top Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Top Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Top Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the battery aside.
  4. Samsung SCH-U340 Top Casing Replacement, Top Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
    • First, remove the plastic plugs covering the screws with a spudger.
  5. Samsung SCH-U340 Top Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver.
    • The screws will need to be pried out after unscrewing them due to their size.
    • Take care not to lose the screws as they are small and have a tendency to roll.
  6. Samsung SCH-U340 Top Casing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
    • To begin removing the outer cover, start by prying the large tab up with a flat object.
    • See next slide for details for smaller tabs.
  7. Samsung SCH-U340 Top Casing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue to pry each smaller tab up, taking care not to break the tabs.
    • If disaster strikes and a tab is broken, the outer casing can still be put back on assuming the majority of the tabs are still intact.
  8. Samsung SCH-U340 Top Casing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the last tab is removed, tug gently on the outer casing to remove it.
    • Don't pull too hard, or you may damage the wires connected to the speaker.
Anish Sambamurthy
crwdns2935283:002/11/10crwdne2935283:0
31 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-21, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 3-21, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S3G21
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,814
