Samsung SCH-U340 Internal Antenna Replacement
  1. Samsung SCH-U340 Internal Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Internal Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Internal Antenna Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the battery aside.
  4. Samsung SCH-U340 Internal Antenna Replacement, Lower Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Internal Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SCH-U340 Internal Antenna Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry the back assembly off of the device.
  6. Samsung SCH-U340 Internal Antenna Replacement, Internal Antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
  7. Samsung SCH-U340 Internal Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SCH-U340 Internal Antenna Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards.
David Gomez
crwdns2935283:001/21/10crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-21, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 3-21, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S3G21
crwdns2942667:0crwdne2942667:0 3,260
