Samsung SCH-A670 Screen Casing Replacement
  1. Samsung SCH-A670 Screen Casing Replacement, Battery Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Screen Casing Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  3. Samsung SCH-A670 Screen Casing Replacement, Logic Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Screen Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Screen Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Screen Casing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SCH-A670 Screen Casing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Screen Casing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Screen Casing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Screen Casing Replacement, Keypad: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the logic board has been removed, peel the keypad up.
  10. Samsung SCH-A670 Screen Casing Replacement, Keypad Housing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SCH-A670 Screen Casing Replacement, Keypad Housing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  11. Samsung SCH-A670 Screen Casing Replacement, Screen Casing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screws with #0 Phillips screwdriver.
  12. Samsung SCH-A670 Screen Casing Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry apart the casing with the spudger tool.
Nathan Brink
crwdns2935283:004/11/10crwdne2935283:0
19 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 34-59, Forte Spring 2010 crwdns2935289:0Cal Poly, Team 34-59, Forte Spring 2010crwdne2935289:0
CPSU-FORTE-S10S34G59
crwdns2942667:0crwdne2942667:0 1,982
