The Keypad may get worn or dirty as time goes by. This guide will aid in the removal of the keypad for cleaning or replacement.
Slide the latch on the back of the phone up.
After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
With a #0 Phillips screwdriver remove the screw which you just uncovered.
Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
Then disconnect the small power connector near the top of the phone.
Gently pry up the ribbon-type connector with the spudger.
Carefully pry the logic board from the case with the spudger.
Once the logic board has been removed, peel the keypad up.
